Wheel size for 48-54 Hudsons
[Deleted User]
Does anyone know the wheel size on 48-54 Stepdowns. I know they are 15 " 5 on ? . What other makes are interchangable?
Thanks
Matt
  • they are 15 on 4 1/2 , AMC , Chry . are a nice fit - Ford is also 4 1/2 but I dont think the Ford center hole is large enough .the Chry-Dodge-Ply. are easy to find in lots of widths.
  • RL Chilton
    15 on 4-1/2 and 5" wide, except for the racing wheels, which were 5-1/2". Do a search for wheels here on the forum. There was a thread not too long ago that Ivan Zaremba talked about the difference and the wheels that he obtained from Smokey Yunick for racing apps.
    Thanks
    Matt
    If you mean exact fit wheels from other makes at that time then that would be Kaiser, Nash and MoPar. The MoPar rims will work but have different retainer clips. All were manufactured by Motor Wheel of Detroit.
  • super-six
    super-six Expert Adviser
    5 1/2" rims were standard on convertibles and optional on all others.
  • RL Chilton
    Larry-
    Are you sure of this? I thought they only difference on the convertibles from all others was tire size? (7.10 versus 7.60)
  • 53jetman
    53jetman Senior Contributor
    Larry is correct on the rim size. A 7:60 was just enough wider than the 7:10 that it needed that extra rim width.
    Jerry
    53jetman
  • nick s
    nick s Senior Contributor
    Actually the 5.5 were only standard on the 49-54 convertibles, and like the closed cars they were optional on the 48's.
  • TwinH
    TwinH Senior Contributor
    But you can make them whatever you want(within reason). PO of my 49
    had 6" hoops installed on stock centers and they work great with the
    P235-75R15 Coker Classics.
