212 optimum cam grind anyone have specs?
terraplane8
With the engine ('36 model) steadily becoming more and more disassembled, I took the lifters out to have a look and found 2 broken lifters with the closing side broken off, plus trenches worn into all the lifters, some 60 thou deep. The cam looked pretty beaten up as well.
Now, does anyone have a suggestion for a cam grind that is better than the standard grind? Geoff Clark mentioned that the later models (post-war?) had a 5" radius on the lifters instead of 4" which gave a bit of a lift in the power. All I'm looking for is an engine that is more efficient, and will have 7:1 compression.
I'm hoping someone can suggest something as the cam needs re-grinding and it will be sent away next week, as well as the lifters to see if they are salvagable.
terraplane8 wrote:With the engine ('36 model) steadily becoming more and more disassembled, I took the lifters out to have a look and found 2 broken lifters with the closing side broken off, plus trenches worn into all the lifters, some 60 thou deep. The cam looked pretty beaten up as well.
I'm hoping someone can suggest something as the cam needs re-grinding and it will be sent away next week, as well as the lifters to see if they are salvagable.0 -
Do check the condition of the phenolic thrust washer behind the cam gear. If it's beat up or missing, it'll eat up your lifters and cam. About $20 from Dale Cooper.0
I think there are a lot of lifters out there that Al Saffrahn has expertly reground and are serving without problems. These old critters have pretty low rate valve springs, so cam and lifter wear isn't as much of a problem as one might expect, especially with modern oils.0
Our company has been regrinding camshafts since 1970, but sold our stock of automotive cam masters a few years ago. We exclusively work on cams for industrial engines now. Sorry I can't help.
Clay
Kams, Inc. - cams and cam followers for industrial engines0
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
