Center Support Bearing
Unknown
I will be replacing the driveshaft center support bearing on a '53 Hornet coupe,(along with the cushions)and I have a NAPA # BR88107. Is this the correct bearing, or is there another number I should have on hand? Thanks, Scott
  • mars55
    mars55 Senior Contributor
    It could be a 88506. Here are the dimensions of the bearings. You can measure yours and pick the right one.
    #88506
    ID 1.1811 inchs
    OD 2.4409
    Width 0.9449 inchs
    #88107
    ID 1.3780 inchs
    OD 2.8346
    Width 0.9843 inchs
