Problems With Hollywood Window Channel
HornetSpecial
I got some rear glass run channel from Victor Zamora for my 51 Hollywood. I am having a rough time making it fit. Seems to be too wide by about 1/8" When I force it in the leading edge closes up. Making the glass not want to fit. Can anybody help with some free advice. It is also differe
nt in height. Has anybody else had this problem with a Hollywood ??
Paul
Paul
Hello Paul , check the following thread, hope this helps: http://www.classiccar.com/forums/showthread.php?t=16506&highlight=victor0
FYI- I bought a complete set channel up for my 52 coupe from Vic at the Western Regional meet. I had all new solex flat glass installed and the window channeling aswell by A&E Bros. glass in Lomita, Ca. Turned out beautiful. Thanks Vic!0
Thanks Vic!! That helps some. I think what has to happen is cloth comes off the sides and glue along the bottom edge about 3/16" from bottom. That will give you all metal again to slide up in channel on car. It is still a little tight. However once you have it in. You can use that paint brush to open somewhat if it is tight on the window.
Thanks Vic !!
P.S. I will kept an eye out for the replacement channel your sending me.
Thanks again0
- 174 The Flathead Forum
- 601 Vehicles
