Problems With Hollywood Window Channel
HornetSpecial
HornetSpecial Expert Adviser
I got some rear glass run channel from Victor Zamora for my 51 Hollywood. I am having a rough time making it fit. Seems to be too wide by about 1/8" When I force it in the leading edge closes up. Making the glass not want to fit. Can anybody help with some free advice. It is also differe:confused:nt in height. Has anybody else had this problem with a Hollywood ??
Paul
  • VicTor Z
    VicTor Z Senior Contributor
    Hello Paul , check the following thread, hope this helps: http://www.classiccar.com/forums/showthread.php?t=16506&highlight=victor
  • FYI- I bought a complete set channel up for my 52 coupe from Vic at the Western Regional meet. I had all new solex flat glass installed and the window channeling aswell by A&E Bros. glass in Lomita, Ca. Turned out beautiful. Thanks Vic!
  • HornetSpecial
    Thanks Vic!! That helps some. I think what has to happen is cloth comes off the sides and glue along the bottom edge about 3/16" from bottom. That will give you all metal again to slide up in channel on car. It is still a little tight. However once you have it in. You can use that paint brush to open somewhat if it is tight on the window.
    Thanks Vic !!
    P.S. I will kept an eye out for the replacement channel your sending me.
    Thanks again
