C8 Exhaust Mani. Studs: UNC or NF?
They are coarse thread. Sorry, don't know the exact length, but this should be a matter of simple measurement. You want to have them so that the nuts are the same height as the thread, so that there is no exposed end of thread to rust and corrode.
Geoff.0 -
The parts manual lists the manifold studs for a stepdown 8 as 3/8-16 x 1-3/8.0
mars55 wrote:The parts manual lists the manifold studs for a stepdown 8 as 3/8-16 x 1-3/8.
thanks for the response. The only studs locally available are coarse one end, fine the other, so i guess I'll just cut some ATR (all thread rod) to use.0 -
The only problem with that is all-threaded rod ahs no base point to screw down to. You can use fine/coare thread studs no problem. Just make sure you use some anti-sieze past on the fine thread nuts, and some sealant around the coarse end which screws into the block to prevent leakage and rusting. I'm pretty sure the studs go into the water jacket in some positions, so it is best to have a blank section to screw the stud down tight into, otherwise you may have leakage up around the threads if you use threaded rod. Good luck,
Geoff.0 -
If you want go mail order, McMaster-Carr offers a 3/8-16 x 1 1/2 studs for $1.54 each.
http://www.mcmaster.com/#90281a630/=1z8lgd
Or unequal threaded for $0.48
http://www.mcmaster.com/#91563a126/=1z8o1t0
- 115 Hudson 1916 - 1929
