Transmission Oil Seal Number Needed
Unknown
Anyone know what rear yoke seal to use in a 37 transmission? Thanks, BUD
  • mars55
    mars55 Senior Contributor
    Does the seal that is currently in the transmission have a part number on it?
    Failing that can you give me an accurate measurement of the seal bore size and yolk?
  • MARS , No numbers,the tranny and rear end appear to use the same yoke and seal . I finally found a parts guy that knew how to read parts books and have one ordered via the size method . Should be here in AM, will let you know what happens. One parts guy "what does it go on ?" 1937 Terraplane . Parts guy " We just sell car parts" About face and hit the door. BUD
  • drdoug
    drdoug Senior Contributor
    Bud,not for sure but I think it is C/R 13710
  • Thanks RON, I'll check that out. BUD
  • barrysweet52
    barrysweet52 Expert Adviser
    I used KOK TC12079-6748 on the front & CR10050 on the back. Regards, Barry
  • Thanks for the info guys. I ended up with a National 473215, it's narrow but it'l work and keep the oil where it belongs and that's what counts. BUD
  • C/R 13710 is the seal number i have also.
