Isuzu steering in a 52 Hornet
Hi everyone, Don from Canada here. I was reading the threads re: power steering from an Isuzu adapting into a Hornet. I have access to a Trooper, that is being destroyed & would like to get the parts out. Can someone tell me what to take ou?? I know steering box & ps pump, but not sure what else. Do I need the column, what about the linkage? at the bottom, pitman arm, tie rod. I'm not sure what to look for. Any advice would be greatly appreciated. Thx Don in Canada, 52 Hornet
Maybe you'd get more results if you posted this on the Hudson Street Rod forum! They are much more creative over there. We're just a bunch of old fuddy-duddies here, who try to make do with the original Hudson parts we were stuck with, LOL!0
Power steering!!!!! Only wussies use such stuff!0
Geoff C., N.Z. wrote:Power steering!!!!! Only wussies use such stuff!
Shame on your hypocrisy Geoff. I've seen your Essex running the "Armstrong" band of P/S!! LOL
:) 0 -
lockport123 wrote:Hi everyone, Don from Canada here. I was reading the threads re: power steering from an Isuzu adapting into a Hornet. I have access to a Trooper, that is being destroyed & would like to get the parts out. Can someone tell me what to take ou?? I know steering box & ps pump, but not sure what else. Do I need the column, what about the linkage? at the bottom, pitman arm, tie rod. I'm not sure what to look for. Any advice would be greatly appreciated. Thx Don in Canada, 52 Hornet
Don....The power rack and pump is about all youd be able to use......The rest of the parts like the linkages and mounts......ALL CUSTOM MADE TO RETROFIT THE HUDSON!........good idea, but a lot of measuring and custom fitting involved........good luck!0 -
Hi Hudson Dave here . I have done four of these converstions on pre stepdowns and they work great. Tom Fink Is the stepdown guro on the stepdown P/S Izuzu converstions . Give him a call 863-439-6480
Hudson Dave 0
- 115 Hudson 1916 - 1929
