Engine & tranny for 47 pickup
[Deleted User]
Here are some pictures of the engine and transmission I got for my 47 pickup.
It is missing the clutch and clutch plate. Does anyone know if the same flywheel can be used with both the 9 and the 10 inch clutches, or are there 2 different flywheels?
  • Geoff
    Geoff Senior Contributor
    The flywheels are not interchangeable between 9 and 10" clutches.
  • Geoff
    edited November 2013
    However, it is my understanding is that the transmission, bell housing, and throwout bearing are interchangeable, is that correct Geoff?
    (The bell housing needs to be matched to the engine, but it should align to the transmission & clutch assembly without issue (?))
    Yes, all you need to change is the flywheel and clutch unit, everything else fits.
    Geoff.
