Information wanted
[Deleted User]
Hi everyone. Has anyone on this board installed 225X75X15 radials on a 54 Hornet without clearance problems? I am going to try that, replacing 760X15 bias ply tires with radials. Thanks for your input.---Cliff Minard.
  • RL Chilton
    I'm sure Nick will correct me if I'm wrong, but the 225's are the radial equivalent of the 7.60's which Hudson used standard on the convertibles. The only difference was, the went to the 5-1/2" rims instead of the the 5" rims with the bigger tires.
    In other words, should work fine.
  • Aaron D. IL
    I've used 225's and 215's and both work but the 225's are a little more of a pain installing on the rear wheel well of a stepdown.
