Hudson Dave
Thank you so much for your order . I can't wait to get the photos with the new tires on it . I will post them on my web page as soon as i get them . Thanks agian Hudson Dave
dave, around the 15th of June I wish to purchase 4 www radial tires to replace my 6.50 by 16 tires on my 41 pickup...what size radial would match the best. I want the widest whitewall I can get on the proper size tire. I will get them from you also..thanks!!....robert bell0
You to Robert I would love photos for the web page:eek: Hudson Dave 0 -
white walls look good dave not a lot else to show
http://www.classiccar.com/forums/showthread.php?t=180430 -
:eek: Look at those FAT WHITE WALLS . LOL The car looks beautiful
You are doing a wonderful job on the car . The more you do the HAPPIER
YOU WILL BE . That is my motto . Hudson Dave from Sunny Florida :cool: 0 -
Hudson Dave,
I have a question about cleaning the white portion of the diamondbacks. Two years ago I bought a set and mounted them, then hung them up using a pipe through the wheel center. Got them down the other day to mount them on the car and noticed a "browning" stain on the whites where the tires had touched while hanging. I tried soap and water and other cleaners to no avail. Can I try some bleach to see if it will pull the stain out?0 -
Hi Hudson Dave here . Try some Wesleys W/W cleaner . Thay say NO BLEACH but if you use once in a while it won't hert them . Continued use over a long time can cause yellowing . If this dosen't work lay them down flat and use lots of water and lightly sand with 320 wet-dry sand paper :eek: sounds bad but it won't hert them . Hudson Dave0
SOS pads do wonders for whitewalls....actually tires in general.0
- 115 Hudson 1916 - 1929
