Hudson Dave
Richie
Richie Senior Contributor
Dave, I'm ready for some WWW tires that we discussed a while back. E-mail me when you get a chance, thanks. Richie.
  • :) Thank you so much for your order . I can't wait to get the photos with the new tires on it . I will post them on my web page as soon as i get them . Thanks agian Hudson Dave ;)
  • bellbigdawg
    bellbigdawg Expert Adviser
    dave, around the 15th of June I wish to purchase 4 www radial tires to replace my 6.50 by 16 tires on my 41 pickup...what size radial would match the best. I want the widest whitewall I can get on the proper size tire. I will get them from you also..thanks!!....robert bell
  • :D You to Robert I would love photos for the web page:eek: Hudson Dave
  • bartibog1
    bartibog1 Expert Adviser
    white walls look good dave not a lot else to show
    http://www.classiccar.com/forums/showthread.php?t=18043
  • :eek: Look at those FAT WHITE WALLS . LOL The car looks beautiful :o You are doing a wonderful job on the car . The more you do the HAPPIER :p YOU WILL BE . That is my motto . Hudson Dave from Sunny Florida :cool:
  • Kdancy
    Kdancy Senior Contributor
    232323232%7Ffp8%3B4%3Enu%3D325%3A%3E549%3E853%3E234%3B549944247ot1lsi
    Hudson Dave,
    I have a question about cleaning the white portion of the diamondbacks. Two years ago I bought a set and mounted them, then hung them up using a pipe through the wheel center. Got them down the other day to mount them on the car and noticed a "browning" stain on the whites where the tires had touched while hanging. I tried soap and water and other cleaners to no avail. Can I try some bleach to see if it will pull the stain out?
  • Hi Hudson Dave here . Try some Wesleys W/W cleaner . Thay say NO BLEACH but if you use once in a while it won't hert them . Continued use over a long time can cause yellowing . If this dosen't work lay them down flat and use lots of water and lightly sand with 320 wet-dry sand paper :eek: sounds bad but it won't hert them . Hudson Dave
  • SOS pads do wonders for whitewalls....actually tires in general.
