Milling Heads On A 212
You can bolt the head from a '39 112 to the 112 block which will result in higher compression and a tad more power. I think that the downside is that it puts more stress on the rods and bearings.
I assume you're already using the version with a dual throat carb which of course gives you increased HP over the base version.0 -
Jon B wrote:You can bolt the head from a '39 112 to the 112 block which will result in higher compression and a tad more power. I think that the downside is that it puts more stress on the rods and bearings.
I have the single throat carb, I know the dual is supposed to give 5 more HP but I don't want to go parts hunting , nor am I trying to build a hot engine , just want to get what HP I can safely out of what I have .---BUD0 -
37 Terraplane#2 wrote:The splasher has been souped up by some guys. Have any milled the heads for more HP, any problems, about how much HP can be gained, how much is safe useing the old stock pistons ?--BUD0
Thanks WALT, like I said, not trying to build a drag racer, just a decent road runner and I DO intend to get it out on the BIG ROAD and keep up with the traffic, nothing more . ---BUD0
- 174 The Flathead Forum
- 601 Vehicles
