Exhausting question
I recently acquired a 1950 super six with what I believe to be a 1952 262 engine. It has the twin h power setup. The exhaust manifold is cracked and I was wondering if it can be repaired? If that is not an option then will any Hudson six exhaust manifold work or does the dual carb setup need a special one? I love these old Hudson but haven't worked on one in many years and will probably have more questions as I get into it. Thanks ..
The 262 or 308 exh manifold will will fit. Just wont have the 2 holes for the choke heat tubes. Very easy to make a small heat box and bolt to manifold for the tubes.0
Hi we always just drill a new heat tube hole in the manafold off of a single and make it a dual it works
good luck
