Water Pump
Roger Harmon
Guys,
I'd like to replace the water pump on my narrow '50 232: It's a little noisey but not leaking (yet). Where can I get one?
R/ Roger.
R/ Roger.
try dave
Dave Kostansek - member- supplier of fuel pumps, water pumps, brake parts, seals, carbs, hoses, thermostats, gaskets, ignition, electrical for most year HET cars.
7902 Route 7, Williamsfield, Ohio 44093 (440) 293-4079 until 10 pm EST0 -
You send Dave your pump and he will rebuild it same as new, does a super job BUD0
Bought several from Dave (OK 3) but never had a problem with them!0
A Noisy Water Pump Is Usually The Result Of A Worn Pulley, Take A Bar Of Soap, Any Brand And Rub The Inside Of Belt. It Will Quiet Right Down. Over The Years, The Surface Of The Pully Is Worn Away, Causing This Problem, Bill Albright, If It Aint Broke, Dont Fix It0
- 115 Hudson 1916 - 1929
