Hudson Speedo Gear Needed
Larger diameter tires will slow the speedo down, less revolutions per mile. What year car are you needing it for ? I may be taking an 18 tooth out of my 50C8 as I has 4 5/9 gears and went to 4 1/9.
Tom.0 -
This would be for a 51 transmission. Are you putting in a gear with less teeth then?
Allan0 -
Yes, The parts manual lists what speedo(pinion) gear is needed by axle ratio & tire size. My 50 C8 with 4 5/9 axle used the 18 T gear, with 4 1/9 used a 15 or 16T gear depending on which tire is used( 7.10 tire used 15T, 7.60 tire used 16T gear). Hope this helps.0
It does answer my question - thanks. I got a call last night and an 18 tooth gear is coming to me.0
- 115 Hudson 1916 - 1929
