Throw out bearing
how do you remove the two pins holding the throw out bearing fork or fingers from the pivioting shaft.? I want to remove it from the shaft. I want to put new bushings on the shaft ends so that the fork presses against the throw out bearing evenly. There is a lot of wobble in the shaft.
The pins are tapper pin. Put the staft into a vise and pound them out starting from the small side. Most move easy. But if it is tough heat it with a torch first. Doug wildrick sells the bushings and pins. he is in the roster in Indiana.0
