Window channelling???
I am trying to find the window channelling for my 52 Pacemaker, not sure whats it called, over here we call it bailey channel. Its the steel backed rubber that fits in the doors and the windows run along when you wind them up. I am about to put an order in with KGAP for some other pieces but can't find this one that I need.
Any help would be greatful.
Cheers,
Adam
Cheers,
Adam
Try Vic Zamora for all your window channeling needs. He has an add in the WTN. Or,thez@verizon.net;(562)947-58540
Thanks Hudson Nevada, I have the channeling you need, but I need to know if your Pacemaker is a two door or 4 door. Also Adam , where are you located? Sedan $145.00, Coupe $160.00. Thanks VicTor0
Hi Vic,
Thanks for the info, I am in Australia, I might see if I can get some over here first and if I have no luck I'll drop you a mail.
Regards,
Adam0 -
Do you have the channeling for a 34 Coupe?0
Yes I would need samples and the measurements. Please mail info to Vic's Auto. Window Channeling , P.O. Box 1908, La Mirada, Ca. 90637, Phone (562) 947-5864 Voice Mail only ! Sorry please leave a message.0
Vic were you at Pamono yesterday?????0
Yes ! I was at Pomona yesterday and Saturday. I am on road 14, sp 46/48.0
I guess I missed you, maybe next time... I didn't see any Hudsons there.
even tho I also have Fords(66Mustang) and Chevies (90 vette, 66 Chevelle 84 el camino) was tired of seeing them..LOL
wanted to see some HET's...0 -
Hello Victor,
I need a set for a '51 Coupe. I sent you an e-mail and a PM.0 -
Hello Dave, just sent reply . Thanks for the inquiry! VicTor Z0
Hi Victor,
Sent reply to your reply. Can you send to my work address? See PM
Thanks!0 -
Vic, Sent you a PM.0
Victor,
Just wanted to know how you have the ends of the catwhiskers fashioned.
Do they have the curved ends with the small flattened tabs that fit under the window channels or are they just straight and cut off at the ends?0 -
rpmonroe, Cat Whiskers (Beltline) at the division bar they are flat and fit between the div bar and the door (outer) and between the Div Bar and the window frame (inner). At the channel side the Cat Whiskers follows the curve of the door to the Channel and they (Ends) are flat and fit outside of the channels . You can flatten the channel where the Cat Whiskers meet the channel. Hope this helps. VicTor Z0
Victor,
The original whiskers that were fastened to the window stainless trim and the interior window garnish molding had curved up ends to match the contour of the widow frames.
Are the sets you have straight from end to end or are the ends curved upward?
I had trouble following your explanation. Sorry0 -
rpmonroe, Sorry about the explanation. I supply the material in a straight form. Send me your Email address to my home, thez@verizon.net and I can send you the instruction. VicTor Z0
- 174 The Flathead Forum
- 600 Vehicles
