Help!
Unknown
I need help with a problem on a 1954, 308, twin H.
The car runs great at idle and down the road but when I come up to stop, she dies.
I have checked everything I can think of. The car has had a complete tuneup, including electronic ignition, "no points". She checks out on the scope.
Open to ideas.
  • Sounds fuel related, possible bad carb float level. Try rebuilding the carb and cleaning/changed the fuel flter.
  • hudsonsplasher1
    hudsonsplasher1 Senior Contributor
    Open to ideas.
    Try checking your idle adjustment screw. Your owners manual should have the correct setting. On my Terraplane it's about one and a half open from closed.
    Gene.
  • RL Chilton
    Gene.
    this is good advice. Keep it simple and try the obvious things before you go and re-build anything. Oftentimes it's the simplest things we overlook. If the idle adjustment doesn't solve it, before you re-build the carb, make sure your float a) doesn't have a small leak in it, and
    b) it's set at the proper height.
