Hudson steering pin issue
Hi!
ive started checking the front suspension in my 52 Hornet , and found out that the steering pin simply needs replacement.
The thing is not that simple , as the original one was a thrust bearing housing. a bearing that would fit to the hole is easy to get (ball thrust bearing) , but im affraid it might be not as strong as the original one .. anyone faced such a problem ? how to repair a worn swivel(king) pin ?
Thanks
Michael
Thanks
Michael
Check with Randy Mass on this forum, he has a repair kit that will improve the original design.
Jerry
53jetman0 -
Michael - are you refering to the center point steering pin or the king pin at the spindle? Norm0
the king pin at the spindle.
what is Randys login ? couldnt find him in the search option ...
Thanks
Michael0 -
Michael: The repair for the king pin wear is to replace the pin with a kit that includes the pin and bearings. These kits are available from time to time on eBay or from Dale Cooper: the following is from his on-line catalog KING PIN SET 1940-54 ALL EXC JET $160
Dale's website is at this URL: www.hudsonmotorcarco.com
Good Luck... keep pluggin looking forward to seeing your coupe... any interim pictures?0 -
Go to:
21stcenturyhudson.net
Have center steering kits ready to ship $80
Randy0 -
maasfh wrote:Go to:
Randy
The problem is the steering pivot pin... ill check with dale , hopefully this would be it , but since i would have to wait more than a month to recieve the package , ill have to do sth on my own..Good Luck... keep pluggin looking forward to seeing your coupe... any interim pictures?0 -
Interim pictures...
What happens to the coupe while it is being restrored. Like Before and soon the AFTER or restored pictures.
Cheers0 -
WildWasp wrote:Michael: The repair for the king pin wear is to replace the pin with a kit that includes the pin and bearings. These kits are available from time to time on eBay or from Dale Cooper: the following is from his on-line catalog KING PIN SET 1940-54 ALL EXC JET $160
- 174 The Flathead Forum
- 600 Vehicles
