Parts go where ?
Unknown
Got a couple of parts I cant remember where I took them off of on my 53 Hornet
  • onerare39
    The piece on the bottom is one of three similar pieces that go around the gas filler pipe. They hold a piece of rubber that seals the filler pipe as it goes through the trunk floor. There should also be three long threaded rods that go through the trunk floor that the three pieces go through.
    Is it all coming back to you now?
    John
    John
    Yeh , it is - thanks
  • RL Chilton
    The top one is a corner brace that goes on the front clip of the frame, outside of the main frame, in the corner of the lateral brace under your cowl and the front frame clip. Make sense? There's holes there for mounting it with fender-type mounting screws. There's a LH and a RH.
    I know these pieces well, I had to make mine.
  • Russ , thanks I appreciate the help
