1954 308 flywheel
Hudson 48-54 except Jet ALL fit but are different for stick or automatic transmission.0
The bolts from my 51 manual shift, are smaller than the bolts in the 54.0
is this a later model engine you think ????0
rdmontez wrote:I'm looking for a 1954 308 flywheel, or an aftermarket swap. I didn't see anything in the swaps manual. Any ideas.
I have a '54 flywheel and pressure plate. PM me.0 -
SuperDave wrote:Hudson 48-54 except Jet ALMOST ALL fit but are different for stick or automatic transmission.
232 w/o od had 9" clutch therefore would be a differnt flywheel.0 -
rdmontez wrote:
the 55-56 would have significantly less bolt holes as it was a dry clutch and no drain hole.is this a later model engine you think ????0 -
nick s wrote:
Every model with overdrive had the 10 inch clutch. Walt.232 w/o od had 9" clutch therefore would be a differnt flywheel.0 -
seems to be some different opinions, I just returned from Ohio and took a look, the 51 has studs, 54 flange has bolts, what do I need to use to mesh my 51 3spd to the 54 engine. thanks guys.0
Sounds like you have a 55 engine. I'm sure others will chime in as to how to adapt it to a stepdown. never been there myself.0
SuperDave wrote:
If you have the 55-56 engine, to use the 54 flywheel you will have to buy a 1/2 inch adapter, which we have members making or change the crankshaft to a 51 to 54. Walt.Sounds like you have a 55 engine. I'm sure others will chime in as to how to adapt it to a stepdown. never been there myself.0 -
well, I guess de-stroking the 308 with the 232 crank is making more and more sense.0
walt's garage-53 wrote:If you have the 55-56 engine, to use the 54 flywheel you will have to buy a 1/2 inch adapter, which we have members making or change the crankshaft to a 51 to 54. Walt.
I am not aware of anybody making the 55-6 crank adapter to the '54& earlier Std. flywheel, but as Walt points out-Change the crank to the 51-54. You will save yourself a bunch of aggrevation. Also by using the 51-54 crankshaft, it will make all the clutch parts standard for your car.0
- 115 Hudson 1916 - 1929
