Need source for parts
Jim Kilday
What is the best and fastest source for ignition points and condenser?
Would NAPA stock these and if so, what is the NAPA Part Number?
I also need to replace the overdrive cable and the control from the heater to the valve on the head? Who might have these parts?
I appreciate your help.
Jim Kilday wrote:What is the best and fastest source for ignition points and condenser?
I appreciate your help.0 -
Fastest way to find an overdrive cable? Have you tried Stu Coleman, in Montana? He might have an old one kicking around. (Contact info's in the National roster)0
For a '46 8 cylinder which uses an Autolite 1GP4008A distributor, Standard lists AL-5661X points and AL-111X condenser which crosses to NAPA CS709 and AL869.0
I got the ignition parts from Dave Kostansek. I figure he can use the business.
I'll contact Stu Coleman about the cables.
Thanks for your help.0
- 174 The Flathead Forum
- 599 Vehicles
