Removing Drivers door Glass
[Deleted User]
How do you remove the roll up door glass on a 53 hudson coupe? Any Advice?
  • Uncle Josh
    Uncle Josh Senior Contributor
    The body manual covers it thououghly.
    Remove lock and garnish moulding
    Remove wood block
    Remove the upholstery trim panel
    Cut door inner liner
    Remove center glass channel screws and remove or lower channell
    Tilt glass inward and raise to upper limit or regulator
    Release regulator cross arms from glass channell and remove glass and channell.
    Reverse procedure to put it back in.
  • dougson
    dougson Senior Contributor
    The manual is the first place to start. Releasing the cross arms can be a little trouble because there is only one spot along each channel where the runners can come free. Loosening everything up will allow maximum up and down travel of the channel and ease lining up the runners with the exit slots.
    In the body service manual it explains it just as Uncle Josh did. It's a job that requires a lot of patience. Walt.
  • hudsontech
    hudsontech Senior Contributor
    And if you want a video - one of John Fromm's National videos shows how to do it. You'd have to ask John which one it is - I got 8 of them here and can't remember which one it's on!!! :D
    Alex Burr
    Memphis, TN
  • I saw a John Fromm video on removing the vent window, I need to remove the Large door glass and replace it. Uncle Josh you said cut the inner liner do you mean the inner metal has to be cut out to remove the glass?
  • I performed this task on my '50 Pacemaker "Deluxe" some years back with no problems. As everyone has suggested, follow the instructions in the Hudson Body Manual carefully. Do make sure to apply something like door grease to the raise/lower mechanism before you seal everthing back in place. Your door window will then open and close much more smoothly than before.
  • hudsontech
    No, I think Uncle J is referring to the paper liner behind the door panel.
    And, yes, you are correct on the vent window. I was thinking that video covered both operations. :rolleyes:
    Alex Burr
    Memphis, TN
