engine removal
hoggyrubber
just a quick question. can the engine be removed from a 52 stepdown with the rad, grille and front sheet metal removed but the fenders left on? if i go right thru the rad brackets is there room or will the manifolds cause probs? should i pull the engine and trans as one? thank you.
hoggyrubber wrote:just a quick question. can the engine be removed from a 52 stepdown with the rad, grille and front sheet metal removed but the fenders left on? if i go right thru the rad brackets is there room or will the manifolds cause probs? should i pull the engine and trans as one? thank you.
Yes you can pull the entire assembly with the fenders and inner panels in place.:D0 -
Yes, as Super Dave said; easiest if use a "cherry picker" with adjustable leveling device to change the angle as you pull it out as well as when putting it back in.
And especially if you've got a Hydro., be sure you've got a sufficiently heavy duty lifting device as you're dealing with a VERY heavy assembly!0 -
thank you both. i have a cherry picker and a leveler. i have pulled and installed quit a few chevy inlines, this will be my first hudson.0
forgot to mention, it the manual 3 speed so it shouldn't be as heavy.0
Yup, pulled one out of a '52 parts car that way about a month ago. I left the trans in the car, but it'll probably come out attached to the engine without too much fuss.0 -
it came out today as slick as could be. now i need to check this puppy out see if it will run, it's been about 15 years according to previous owner.0
- 174 The Flathead Forum
- 599 Vehicles
