WA-1 carb question
JimC1 wrote:Is there anyway to put an electric choke on a 1953 Hudson WA-1 carb? If so, who sells it?
Anyone ever tried this? Is there a chocke-stat that will fit on the WA-1 carbs?0 -
Curious as to why you would want one? Is your old one broke? Replacements can be found.:)0 -
RL Chilton wrote:Curious as to why you would want one? Is your old one broke? Replacements can be found.:)
Well, for one thing you don't need to worry about the heat riser tubes to the choke housing with electric chokes...
I looked when I started rebuilding my WA-1's, I couldn't find a direct x-over replacement.
But, there have been so many carbs made over the years with electric chokes - If someone had time and access to compare dimensions of the stock assemblies I don't see why you couldn't find an electric choke that would fit in the WA-1 carbs.0 -
In your search for an electric choke to adapt, best remember that most electric chokes will be 12v as they were not developed until the early to mid '70s.
Jerry
53jetman0 -
JimC1 wrote:Is there anyway to put an electric choke on a 1953 Hudson WA-1 carb? If so, who sells it?0
Here's an interesting article on the history of automatic chokes, written by a carburetor restorer. He discusses the pro's and con's of electric, hot air, water, and other types of automatic chokes. I'm afraid he doesn't have a lot of good things to say about electric chokes, but maybe they're improved since he wrote this! http://www.thecarburetorshop.com/Automaticchokes.htm0
Of all the headaches I got from carburators I can't say replacing the thermac coil has occured to me. I might feel different about the manual choke on my chevy 216 but haven't driven it enough yet.0
- 174 The Flathead Forum
- 599 Vehicles
