Twin h carb return springs
[Deleted User]
Can someone post a pic(s) of how the Twin H carburetor throttle return springs mount? Thanks.
    On the rear stud that bolts the carb down you have a piece that has a hole on one end and a notch at the other end that locks against the carb. The spring goes into the hole and into a sliding clip on the rod. The rod has a built out piece that keeps it back to keep tension on the spring. You must have the correct spring for the correct throttle pedal pressure. Too heavy of a spring and you end up with one tired foot. I have these springs. Sneaky way to get that in. Walt.
  • onerare39
    Here you go. Pictures to go with Walt's words :D
  • Thanks Walt and onerare39, exactly what I was in search of. Walt, do you sell these elusive springs?
    Dave
  • If he dosen't, I do. NORS. As many as you want.
    Hudzilla,
    Do you wanna sell me a couple?
  • Dave, You have a PM.
