hudson starter
ski4life65 wrote:
Thats kind of high priced isnt it ?? I should have one - mines is free + shipping , Give me a day or two to check it over0 -
MCH-6204?? All my research and records indicate starter MCH-6107 was used with hydramatic from 1951 thru 1954.
Alex Burr
Memphis, TN0 -
hudsontech wrote:MCH-6204?? All my research and records indicate starter MCH-6107 was used with hydramatic from 1951 thru 1954.
Alex Burr
Memphis, TN
Alex you are partly correct. That MCH 6107 was used on the '51 with hydramatic. Starting in 1952 the MCH 6204 was used on the 232,262 and 308 hydramatics up to 54. Hollander lists them as interchangeable, so either would work on hydramatics 51-54.0 -
Checked mine out after I finally found it - it spins good but drive wont kick out , Im sure it needs torn down and cleaned up0
Hudzilla wrote:Alex you are partly correct. That MCH 6107 was used on the '51 with hydramatic. Starting in 1952 the MCH 6204 was used on the 232,262 and 308 hydramatics up to 54. Hollander lists them as interchangeable, so either would work on hydramatics 51-54.
Just to add to the mix.. I have a 54 308 hydramatic with 12 volts.. Using a Jet starter..Been working for three years. Smaller, but a bolt on. It was put in while I rebuilt the original starter. Thought I would see how long it lasts..still ticking.:eek:0 -
SuperDave wrote:Just to add to the mix.. I have a 54 308 hydramatic with 12 volts.. Using a Jet starter..Been working for three years. Smaller, but a bolt on. It was put in while I rebuilt the original starter. Thought I would see how long it lasts..still ticking.:eek:
I'm not surprised - Chrysler Corp. used 6 volt starters with 12 volt systems for a number of years. You can always tell when you hear one - sounds like the starter is going to take off and outrun the car.
Alex Burr
Memphis, TN0 -
Hey Stateline,
HudMan is my dad. He saw your ad over at my house and asked me to reply for him.
He says, "How do I go about finding out how much shipping would be? Yes, I am VERY interested in getting yours from you! THANKS A BUNCH!!".0 -
have him pm me his zip code , its pretty heavy I'll get a UPS price , we need to move fast , My, ip is dropping dial-up at years end which will put me off the net .0
my zip code is 77484 waller texas you don't really know how much this helps me out. recently unemployed, this is really appreciated. gonna have to change your name to santa. if i can ever help you out with anything i'll be on it like white on rice. once again thanks alot. have a very very merry christmas 51 hudman0
51 HudMan , shipping will be $25 - email me HudsonHornet at wir.net, and I'll give you imformation0
If the starter from WY does not work out let me know, I might have one laying around and I am in the Fort Worth area, I have two or three of them somewhere. Thanks
Hudson0 -
HudMan I PMed you my email address ?- I'll still send you the starter if you need it .0
- 174 The Flathead Forum
- 599 Vehicles
