1952 Hudson Hornet - $3500 Craigs List
Area code and prefix show it as Medina, NY.
That's what I sold my '53 Wasp for in 2005, in apparently the same condition as my old car.0 -
66patrick66 wrote:Area code and prefix show it as Medina, NY.
This '52 has Twin-H, motor is frozen. It had a leaking head gasket replaced and began leaking water into the oil that fall and was parked for the winter, following spring motor was frozen. The owner says it is a '53 motor but also said it had a lifter noise, '55 or 56??
Needs a headliner, hood ornament, two chrome pieces under trunk lid and chrome replated. Balance of trim is supposed to be in boxes from when he bought it from previous seller.
I am supposed to be getting pictures of the trunk and underneath, if I do I will post here.
I called on this because I was interested. but I already having a '52 that needs some plating done and with the high cost of chroming I am beginning to back off '51's to 53's.0 -
"I called on this because I was interested. but I already having a '52 that needs some plating done and with the high cost of chroming I am beginning to back off '51's to 53's."
Newcomer's should certainly take this into account. Absolutely factual, I can attest to it's validity. Good morning, Pat!0
- 115 Hudson 1916 - 1929
