1952 Hudson Hornet - $3500 Craigs List
[Deleted User]
not currently running
automatic, 308 6 cyl.
4 door
new brakes, tires, water pump, heater
lights work, solid car
call Sam (585)798-1243
I know nothing about this car... the pictures show a decent car with what looks like an original interior.
  • Area code and prefix show it as Medina, NY.
    That's what I sold my '53 Wasp for in 2005, in apparently the same condition as my old car.
    This '52 has Twin-H, motor is frozen. It had a leaking head gasket replaced and began leaking water into the oil that fall and was parked for the winter, following spring motor was frozen. The owner says it is a '53 motor but also said it had a lifter noise, '55 or 56??
    Needs a headliner, hood ornament, two chrome pieces under trunk lid and chrome replated. Balance of trim is supposed to be in boxes from when he bought it from previous seller.
    I am supposed to be getting pictures of the trunk and underneath, if I do I will post here.
    I called on this because I was interested. but I already having a '52 that needs some plating done and with the high cost of chroming I am beginning to back off '51's to 53's.
  • RL Chilton
    "I called on this because I was interested. but I already having a '52 that needs some plating done and with the high cost of chroming I am beginning to back off '51's to 53's."
    Newcomer's should certainly take this into account. Absolutely factual, I can attest to it's validity. Good morning, Pat!
