interior Timber Triming
essexcoupe3131
essexcoupe3131 Senior Contributor
Hi All have started, trimming out the timber work inside on my coupe for the upholstery, its not going to be stock, but I would be interested in seeing any existing standard coupes timber work to see where they had timber work especially to the rear wheel arches in the rumble seat area or any associated steel work, I have completed the front timber door pillars, roof area, rear window frame and rear window rain tray,
the rear window and side wall upper panel (above parcel tray) which I have curved in flexy ply to retain the curves in the corners and have set a set of speakers in these corners which I have found a set of JVC wood speakers which will be rebated into these enclosures which will tie in nicly with the wooden steering wheel and rumble seat foot rest
I am trying to get ideas so any help would be appreciated as they say a picture tells a thousand words
thanks for your help
Mike
  • Mike:
    I had to do a double-take on the "timber trimming" I thought that you were about to tell us about being a lumberjack out there clearing the forest... :D
    Maybe you should re-post as "interior woodwork trim and framing" to get more responses.
    Craig
  • essexcoupe3131
    There you go done and
    thanks
    Mike
  • essexcoupe3131
    Us Kiwi's try to speak the queens english
    must have been my up bringing, dragged up by the scuff of the neck LOL
    Mike
  • Now I certainly understand being "dragged up by the scruff of my neck" The wife does it all the time to me....
    Craig
