instalation of inner fenders
getting ready to install inner fenders and looking for help. what kind of a seal goes at the bottom of the piece shown in the photo. perhaps it keeps dirt from getting to frame area. this piece is mounted to fire wall. are any parts for this reproduced?
steve
steve
What year? Probably the gravel guard I'm looking for. KGap used to have them but do not now.0
Actually it's an "L" shaped piece of sheetmetal with a long dust seal parallel to the back side of the fender. It screws onto the firewall At the bottom of the "L" there is a mudflap that goes from the frame rail around to the outter side of the sheetmetal "L". You can actually fab a piece of rubber that will work just as well.Find someone who sells rubber sheet goods and cut it to fit from an old pattern.0
its for a 1953 super wasp/ anyone have a picture?
steve0 -
I fabed one for the drivers side out of an el cheapo door mat-rubber-from "Ollies" [a junk type outlet],worked fine but then who has one of those "super" staplers,I used small washers and a "shop" grade pop rivet gun,hardly seen and works-51 cpe0
- 115 Hudson 1916 - 1929
