Ranco valve.
Geoff
Geoff Senior Contributor
Can someone please tell me where the capillary tube from the Ranco valve is supposed to go on my '53 Hornet. At the moment it just hangs in the air! Thanks,
Geoff.
  • Your capillary tube goes and lies flat against the interior firewall until the end of the tube attaches to the blower assembly. It should have a small clamp at the end. This goes onto the bottom screw on the blower assembly where the tray attaches to the plenum, HOWEVER not all Rancos had this setup. Some had an abbreviated capillary tube that terminated almost at the valve itself. Whatever you do, DO NOT rupture the capillary line or rupture the bladder. If you do ,barring obtaining a replacement bladder, you have destroyed your Ranco.
  • Geoff
    Thank you for the information, I have now attended to this.
