Need NAPA Part Number for 12V Electric Fuel Pump
I have a Carter P60430 12v gear driven pump mounted to the trunk riser sheet metal right over the gas tank in my 53 Hornet. It is small(really small) and will put 30GPH. A pressure regulator(it will push 7 PSI, $20) and I suggest a check valve( if you are removing the mech pump, $10 Mc Master-Carr).Summit is the cheapest price(Summit Racing.com), under $55, filter included. Rotary vane pumps work well also, but are $100 and need more space and the same additions.0
Not all those "fuel filter looking" electric pumps have problems with modern gas --- depends on the materials used. I've had one on my Hornet for over five years and about 25,000 miles, with no problems.0
I just bought a "Mr.Gasket Co" brand from Auto Zone for $40.49-with a car clun 10% discount.It says for all 12 V carburated 4.6.8 cyl applications. This is the third one i have used on different cars I have helped convert to 12 volt.I let the mechanical pump take over after starting and do use an in line filter at the tank are instilation.There is no NAPA store here as the others have run them out due to highte prices0
nhp1127 wrote:Anyone know the Napa part number for a 12V electric fuel pump that will work on a Hornet? Mine has already been converted with one and seems to be now having fuel delivery issues (pump is about two years old). I haven't removed it yet to see the part number. Thanks!0
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 75 Hudson 8
- 597 Vehicles
