Molding
I have a 1950 Hudson Pacemaker, an early one with oval trim. I am in need of the rear quarter moldings, the oval style, not eyebrow. They measure 44 3/4"' long. The ones I have were drilled and attached by sheet metal screws. I would appreciate any help in getting new ones or if someone knows of a good stainless welder. Thanks.
Whats the difference between the oval & the eyebrow, Thanks.0
They are in the process of being reproduced. Do a search of this forum and you will find the thread. Those pieces are used on 48-49 in stainless and painted from 51 and up. The Eyebrow is a one (50) year only part. Lucky you have an early model with the 49 oval.0
I also need those two pieces, but do not know if I have eyebrow or oval, what difference will I see by looking at them.
Thanks0 -
I can straighten and polish the ones you have and the holes can be fixed as well.........just let me know0
Inspector123 wrote:I also need those two pieces, but do not know if I have eyebrow or oval, what difference will I see by looking at them.
Thanks
The cross section of the oval moulding is a smooth 1/2 oval shape. The eyebrow is the same width but the cross section has a "dip" in it. That's the only way I know how to describe it. other than if it isn't a smooth oval shape it's eyebrow. You can compare it to the 51'sthat had a stainless trim halfway down the lower door section that is an "eyebrow" shape.I'm sure one of the wordsmiths on this forum can describe it better.
Looks like I have the eyebrow one, it dips in the middle as tou described. Thanks0
Update on these moldings. He is telling me that he needs two more weeks on them. Will keep you posted
Russ Maas0
- 174 The Flathead Forum
- 599 Vehicles
