flywheel-308 hydromatic
I think I have a crank with one on it. Do you have a pic I can match it with? I'm in Northern NYState
HETcramerlp@roadrunner.com & drop the HET0 -
51HudMan wrote:mine is pretty chewed up.looking for one cheap. thanks0
Better go with Walt. I looked around in the shed today and it must be under something. Has the crank still attached and I can't see it anywhere. Gonna have to clean the shed out I guess.0
Just to ad a note to Walts post. In 1954 Hudson called the BorgWarner transmission "Automatic". I don't know why! That flywheel is not interchangeable with the Hydra-Matic. Borg warner used a flexplate and separate torque converter. Hydra-Matic flywheel was the front part of the converter.0
SuperDave wrote:Just to ad a note to Walts post. In 1954 Hudson called the BorgWarner transmission "Automatic". I don't know why! That flywheel is not interchangeable with the Hydra-Matic. Borg warner used a flexplate and separate torque converter. Hydra-Matic flywheel was the front part of the converter.0
- 174 The Flathead Forum
- 599 Vehicles
