36 head light buckets
essexcoupe3131
here is some head light buckets not sure if right year
http://cgi.ebay.com/ebaymotors/1936-HUDSON-HEADLIGHT-BUCKET-NICE-PAIR-1935-1937_W0QQitemZ160402753983QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2558bfc9bf
Mike
Mike
i could be mistaken, but they look like the depress beams on my '35, but with sealed beam adapter???? regards, tom0
I'm not sure what they fit on other than 36's. But they are definately the ones for 36's. I have two sets of them in my shop..... they look to be in reasonably good restorable shape and have all the right attach hardware inside other than the springs that go on the reflectors.....0
Anyone have an idea or pic of what the springs look like for those reflectors that hold the outer ring on? Or better yet, where to get them!?
Mine are converted to sealed beam but the just put screws through the outer trim ring. I would like to repair them and use the springs to hold them on.
Thanks,
Jeff0 -
Yep!! Donald is the man.....0
If the insides of the '36 are the same as the '37, then Duke Marley has repro's of the special long spring at the bottom through which the attaching bolt goes. Being at the bottom, this spring is usually the one that rusts out long before anything else. The other two springs are identical to one another, but different from the bottom spring.0
The three springs on my 36 lights are the same.0
- 115 Hudson 1916 - 1929
