Hudson distributor?
Unknown
Can anyone ID the distributor pictured below? Year? Model?
Thanks!
  • Aaron D. IL
    Looks 6 cyl step-down in origin to me.
  • That would put it in the 1950-52 range, correct?
  • hudsontech
    hudsontech Senior Contributor
    IAT-4009A - 1951-1952 all 6 Cyl. exc. Pacemaker.
    Information available on my web site @ www.hetclub.org/burr - can be found on Equipment Manufacturers Numbers. Also in my "General Information Handbook for Hudson Built Automobiles".
    Alex Burr
    Memphis, TN
  • You guys are GOOD!
    Thank you!
    Jim
  • SuperDave
    SuperDave Senior Contributor
    The distributors "fit" from 48 to 54 and beyond. There are two basic designs that use different rotors, caps and point sets.. Other than that, biggest difference is the vacuum and centrifical advance curve. I run a 54 308 distributor in my '49 262, but I do have a 308 cam, a little higher compression,Twin H, and Pertronix ignition.
    Thanks!
    Thats a red label 51 model for everything except Pacemakers.
  • hudsontech
    Now that's something I didn't know - that the lables were color coded.
    Learn something every day. Thanx Hudzilla.
    Alex Burr
    Memphis, TN
