does anyone use the clutch oil from the club?
schillaz
schillaz Expert Adviser
I just purchased some clutch oil from the hudson club and it seems really runny almost like water? i thought it would have to be alittle heavier? Has anyone used it and is it ok to run? was there any left when you went to drain it?
thanks,
  • Park_W
    Park_W Senior Contributor
    It should be fine. The original Hudsonite was thin. To give you an idea, as an emergency substitute they recommended a 50-50 mix of 20 weight motor oil and kerosene. That's pretty thin.
  • Aaron D. IL
    I use it, no complaints. I havn't burned out any clutches using it or anything if that's what you mean.
  • Just got some recently and it's working fine. Actually the thinner a liquid is the better it cools . BUD
  • Richard E.
    Richard E. Senior Contributor
    I've used it for years in both my '50C6 and my '36T, no complaints.
  • oldhudsons
    oldhudsons Senior Contributor
    my test has always been a "nose test". If you smell original Hudsonite it has an unusual odor + it is also dark in color. The main purpose of the Hudsonite is to keep the cork soft so they won't harden & crack.
    I've found after installing a new clutch disc, after a few weeks, a good idea to drain the Hudsonite (& I always drain it into a measuring cup to see exactly how much came out) as some will have been absorbed by the new corks & refill it.
    One of the 1st things I'd always do after purchasing a Hudson would be to drain the clutch & replace whatever was in it. Sometime literally nothing, sometimes way too much.
    I can't remember how viscuous Hudsonite is as haven't "done" one in a few years but have a 1 gal. can of the original stuff I've been using for years + have some of the small cans Permatex made for the Club many years ago.
  • schillaz
    Ok thank you guys for all the info. I appreciate your opinions.
