Hornet horn ring assembly - HELP!!
Unknown
hi guys!
i have a huge problem here - ive started to assembly the steering wheel , and it came to me - i should have done some pictures :(
look at the picture - this is how far i went, i thing im missing something as the horn ring doesnt spring back , but have no idea what should go there..
Pls help me!
http://img443.imageshack.us/img443/2805/dscn2142u.jpg
  • dougson
    dougson Senior Contributor
    You should have removed a broad, loosely coiled spring at some point.
  • eergh it was a long time ago ;( where did the spring go ??
    Thanks
  • RL Chilton
    Veyron-
    There's a spring that the horn button itself slips into. That button is 'T'-shaped. Additionally, there's a thin brass bar, or plate that goes across the horn button and clips into those long oblong slots on the outer edge of the central hub of the wheel. I'm fixin' to go out of town, or I'd post some pictures. If you can't find the spring, contact Hudzilla here on the forum, I'm sure he probably has some.
