vent Window Regulator - stepdown
DocHornet
DocHornet Expert Adviser
Is anyone making new replacement vent window regulators for the Hornet? One of mine is in serious need of replacement. (a good used one, driver side, would be the next option)
  • RL Chilton
    Phil-
    No replacements that I know of. Have to stick with a good used one. Hudzilla here on the forum, Albright's Twin-H Ranch in CA and Bill & Charlie's are good starting points. Just do a search here on the forum for contact info.
  • duncan
    duncan Expert Adviser
    Gene Echelman of Weiser Odaho makes new replacement vent window gears for stepdown.:D
  • ski4life65
    ski4life65 Expert Adviser
    Gene has an ad in the WTN. The gears are $27.50 each
  • Gene also sells them on E-bay His E-bay user ID is Gandm
  • DocHornet
    Thanks for all the help guys. I did make contact with Gene ESHELMAN via his eBay user ID. For others who might be interested, he does provide the new gears at $55 for the pair, or an additional $20 each for him to install the gears in your regulator. He's in Idaho:
    Phone contact.
    208-549-3571 OR 208-550-0360 OR 208-550-1535
  • RL Chilton
    Well, I'm a dope! If I had bothered reading the "VENT" part of the description, I sure coulda pushed you in the right direction, as I've bought two sets from Gene . . . amongst other things.
