vent Window Regulator - stepdown
Phil-
No replacements that I know of. Have to stick with a good used one. Hudzilla here on the forum, Albright's Twin-H Ranch in CA and Bill & Charlie's are good starting points. Just do a search here on the forum for contact info.0 -
Gene Echelman of Weiser Odaho makes new replacement vent window gears for stepdown.:D0
Gene has an ad in the WTN. The gears are $27.50 each0
Gene also sells them on E-bay His E-bay user ID is Gandm0
Thanks for all the help guys. I did make contact with Gene ESHELMAN via his eBay user ID. For others who might be interested, he does provide the new gears at $55 for the pair, or an additional $20 each for him to install the gears in your regulator. He's in Idaho:
Phone contact.
208-549-3571 OR 208-550-0360 OR 208-550-15350 -
Well, I'm a dope! If I had bothered reading the "VENT" part of the description, I sure coulda pushed you in the right direction, as I've bought two sets from Gene . . . amongst other things.0
- 115 Hudson 1916 - 1929
