37 rear shock mount bolt
this 37 chassis was stripped when it was brought to me. I've looked and can't find what I think might be the shock to frame member bolts. Looks like one side is bigger than the other (one is .063, the other .477 and the length in between the tabs is 1.23")
Does some one have them or a picture of them so I can make two up?
Think your in the right place Kerry. THE TAbs are on a cross member well in front of the axle . It has a rubber stop bumper on the cross member over the differential housing . The bolt is down sized so you can tighten it without squashing the tabs . you'll have to turn a bolt down and cut threads on it .
----Have you still got that locked up steering gear box ?
BUD0 -
37 Terraplane#2 wrote:Think your in the right place Kerry. THE TAbs are on a cross member well in front of the axle . It has a rubber stop bumper on the cross member over the differential housing . The bolt is down sized so you can tighten it without squashing the tabs . you'll have to turn a bolt down and cut threads on it .
BUD
Bud,
OK -- that is what I was thinking. I stated cleaning up and taking apart the better gear box yesterday. I need to get some new seals but it looks good at this point. What color should the steering box be painted?0 -
paint er black , same as chassis
BUD0
- 173 The Flathead Forum
- 599 Vehicles
