Any one interested in aluminum valve/tappet covers?
GrimGreaser
I had to pull the manifolds off last weekend due to a busted carb stud, and seeing the filthy state my 308 is currently in I pulled off the valve covers to clean 'em up too. Now I've got plans rolling around in my head about making some finned and/or 'HUDSON' scripted covers out of aluminum. I've got plenty of CAD experience and access to a nice CNC milling machine.
I'm thinking simple finned cover with a standard PCV/breather grommet hole for the back and a finned/HUDSON cover up front where one has a better chance to see it tucked under those manifolds.
Who might be interested? I have no idea about price or anything like that right now, just trying to gauge interest. I'll update when I have some drawings made up, too.
Also, pondering a simple adapter to bolt a regular Chevy/aftermarket waterneck and thermostat in place of the Hudson unit. Simple aluminum plate, bolts to head then waterneck bolts to the plate. Any thoughts on that?
«1
  • brumac
    brumac Expert Adviser
    Hi Grim Greaser,
    I think that is a great idea and would be interested in the tappet covers if the price isn't out of sight As to the water outlet, I like the shape of the old Hud gooseneck. I use a simple flat plate to almost block off the bypass just like Walt Mordenti suggests and that works fine for me.
    Brucehttp://classicar.com/forums/images/smilies/smile.gif
  • i would be interested in two or three sets of these for the 232-262-308 engines.
    thanks,
    Ralph
    aka: PaceRacer50
  • dougson
    dougson Senior Contributor
    Sure, aluminum valve covers would be great! :D
  • MikeWA
    MikeWA Senior Contributor
    I'd be interested as well- to go with that finned aluminum head that somebody's just GOTTA make. . .oh, and the manifold for 3 Rochester 2 barrels. . . and. . . and. . .
    You can't be too thin, or too rich, or have too much bling on your hot rod. . .
  • GrimGreaser
    Quick Solidworks model. Not dimensioned, not final...
  • hornet53
    hornet53 Senior Contributor
    Put me down for 2 sets if this comes to be. One for the car and one for the future car!
    What are you thinking for gaskets?
  • TwinH
    TwinH Senior Contributor
    I'd take a pair. And just to throw out for discussion,how bout a register
    on the back to locate the gasket? Also,I'm not opposed to running a PCV
    setup and like the idea but currently using the road draft tube with the
    Clifford headers. Have you considered any baffling for the PCV port
    (or is there even room)?
    Anybody running a PCV with a Twin-H manifold? Where did you plumb
    the vacuum source? Pics would be even better.
  • hornet53
    Are they done yet?
  • GrimGreaser
    What you can't see on the back is the relief to index the cover and gasket onto the engine. Plan to have these use the standard cork/rubber gasket. Though, there's all sorts of interesting gasket material at McMaster.com one could play with.
    I've used these: http://www.summitracing.com/parts/SUM-G3413/ on my Chevy and they work pretty good.
    There should be enough meat (plan cutting these from 1/2" plate) on the back to bolt any sort of baffling one would want, even a mount for the draft tube.
  • brumac
    Those look GREAT. Sign me up for a pair.
    Bruce
  • essexcoupe3131
    essexcoupe3131 Senior Contributor
    all you boys are spoilt for choice, good on ya GRimGreaser for thinking of the community
    Mike
  • Let me know the price, two pair. Thanks, Bob
  • ivanz62
    ivanz62 Expert Adviser
    I would buy several sets, but would want provision for the standard road draft tube. No PCV. Having enough engagement through the gasket into the block is the way to go--you have to do this behind the headers and any alignment help is a good thing!
  • GrimGreaser
    Glad to see folks are interested, I'll do my best to get these going. Figured I could use my fancy degree for something I really enjoy. Not that this requires a whole heck of a lot of engineering, but I sure did spend a lot of money to learn to use SolidWorks...
  • dougson
    So please add a pair w/pcv.
  • Not yet finished with '52 Hornet and don't know if I'll attempt to restore '56 Twin-H Powered Hornet, but just in case I do, depending on price I may buy to keep on shelve?
    Thanks,
    Ray
  • I'd be interested in a set if they are reasonable.
  • GrimGreaser
    Updated design:
  • ivanz62
    I prefer the original design myself!
    Please keep in mind that the original steel parts often were bent by over tightening and didn't seal well as a result. Make 'em thick enough where it counts. The original design looks like it might get more stiffness from the ribs, but I'd buy either style.
    Thanks--Ivan
  • GrimGreaser
    I know what you mean, but the previous design was done up from memory. 3 x 9 was what i started with, but the covers are actually ~3.5 x 13.5. Having the bolt holes in the 'U' and 'O' might still work, have to play with it. I switched because it was a pain to set up the letters that way. I considered sqeezing the HUDSON in between, but to keep the cut time (and thus price) down the letters need to be nice and big to be able to use larger cutters. Don't worry about thickness, these will be cut from 1/2" plate.
    Nothings final yet. :)
  • GrimGreaser
    I like this much better. The fins are trimmed down 1/16 of an inch to reveal the letters.
    Here's a view of the back, 1/4 inch relief to hold gasket and align the cover with the engine:
  • hornet53
    Any further progress?
  • GrimGreaser
    The gears are turning... I'm waiting for my buddy to get back from business travel and to free up some time on his companies CNC. Plan is to cut some test covers, see how long and involved they actually are to cut out. From there refine the design again and come up with prices. Then I'll start queuing up orders in the order folks expressed interest here, if they're still interested.
    That said, many of you guys have said 'reasonable price' here. Well, what do you guys see as a reasonable price? Keep in mind, these will be time and toolbit intensive (at least for the 'HUDSON' cover). Anodizing (red, black, clear) may be available, but I don't want to get ahead of myself here.
  • essexcoupe3131
    Hi grimgreaser, Some good solid carbide cutters and fluid will make easy meat of the Ali
    1 jig and you got it for as many as you want, I would have done a bit more of this sort of stuff but my CNC doesn't have fluid running with it, was made for wood instead of metal and as you now it makes a lot of mess,I spent too much time cleaning up last time
    Mike
  • GrimGreaser
    Believe me, my friend knows how to make his CNC cut damn fast, and more than 90% of the cutting is with at least a 1/4 inch tool. It's the 1/8 and 1/16 inch cuts, while minimal, that slow everything down. However, until we actually cut some out I want to remain mute on price.
  • faustmb
    faustmb Senior Contributor
    Those are sweet !
  • GrimGreaser
    The one with the PCV/breather hole has been cut. The one with letters should be cut Tuesday.
  • brumac
    OH MY, that sure does look lovely !!!!
  • ski4life65
    ski4life65 Expert Adviser
    WOW! I like it.
  • bigboy308
    bigboy308 Expert Adviser
    Lookin' GOOD!!
    Put me down for a finished set----
    THANX!
