1936 hudson front&rear fenders
Rocket
Rocket Senior Contributor
I just picked up a 1936 hudson long wheel base and would like to know if the front & rear fenders on a coupe or sedan are the same or do I have to find ones from a long wheel base also dose anyone out there have a 127 inch frame they would like to part with thanks in advance.:confused:
  • Park_W
    Park_W Senior Contributor
    Best to confirm it with the parts book, but they should be the same. All the length difference is at mid-body. The fronts do need to be Hudson though, not Terraplane, as there's definitely a difference between those two.
  • 53jetman
    53jetman Senior Contributor
    If you check the parts book, your will find that coupe rear fenders fit only the coupe and convert bodys.
  • junkcarfann
    junkcarfann Expert Adviser
    That may be because of holes for the Rumble seat? (1936 was last year for that)
  • Richard E.
    Richard E. Senior Contributor
    I can tell you from experience that '36 Hudson side mount front fenders differ from '36 Terraplane sidemount fenders. The pocket is placed in at a different angle and yes, they have different part #'s. Otherwise they are the exact same size. Very interesting!
  • bent metal
    bent metal Senior Contributor
    How do you know that "Richard E."?;):D haha, it's crazy to me how often I hear of little changes like that, that were done at the factory for what had to have been great expense for a small change to a certain year or even model.:) Usually for no apparent reason.
