Source for rubber supplies? ? ?
[Deleted User]
Is there another source, besides Kgap, for the axel spring rubber mounting pads for my 54 Special?
Thanks,
Doug
  • Aaron D. IL
    Some years ago you could order a few things from Steel Rubber products who also got their stuff through metro molded products but I do not know if that is still the case. To get anything from metro molded you have to go through an authorized distributor and I hear Steel and others are mostly pretty expensive anyways if not over-priced.
  • Aaron D. IL
    BUT...if you're only talking about flat pieces of rubber why not just find some rubber stock and cut it out yourself?
