'35 Hudson horn button insert
Does anyone know who would be a good source to get a horn button insert for a '35 Hudson? If none are out there, then if I can at least get a picture or drawing of one to possibly create on my own with metal or tin would be helpful - just want to get the dual trumpet horns working again! Thanks
Exactly what part are you after, the button in the centre or what.???0
anyone know if 35 and 37 are the same? ALAN , measure the opening in the wheel and post a pic of wheel--- BUD0
They are not the same.0
JON , I know the 35 and 36 is a keyway fit and the 37 is splined. Other than that are they different ?0
I'm sure the 1937 is a much larger diameter than the 1935-6 button. It's a different finish and shape, and most probably it attached in a different way. It is neither splined nor keyed; to install it you press it down then rotate slightly and release.0
If you are only after the button, I can do that, in white or black second hand.0
Jon B wrote:I'm sure the 1937 is a much larger diameter than the 1935-6 button. It's a different finish and shape, and most probably it attached in a different way. It is neither splined nor keyed; to install it you press it down then rotate slightly and release.
The wheel JON, the wheel !! Anyway you answered the question , entirely different wheel and button . Thanks , BUD0 -
Huddy42,
The part I am looking for is the metal insert ; the white plastic horn button in the middle unscrews and the metal insert is right underneath used as a contact to allow the horns to work. I saw a sample of one several years ago, but could not remember the detail. Bud, Jon, thanks for your input also - I did contact Terry Johannes who also owns a '35 and he said he may have an extra insert - will post an update once I hear back from him - again, thank you gentlemen for your replies.0 -
In a pinch, I wonder if the whole thing might be fabricated? White plastic could be lathe-turned to get the proper shape, and various steel / bronze / copper parts could be soldered / welded together to make the contacts. Never underestimate the resourcefulness of a Hudson owner!
For example, back in the benighted 1970's when Hudson reproductions were rare, I needed a "flying carrot" hood ornament for my '37. So desperate was I, that I bought a Plexiglas acrylic rod and had a fellow worker lathe-turn it in the shop, to the Zeppelin shape. Then I cut three pieces of brass and hand formed them into the "wings" that surround the carrot. (I did happen to have a pot-metal base.) The result doesn't look half-bad at 20 ft. away! I am a draftsman, not a craftsman; I don't even own a table saw. But it's amazing what desperation can accomplish.0 -
Good news - Terry was able to locate an extra insert he will be mailing to me.
Thanks for the pointers Jon - I agree that sometimes you have to be prepared to fabricate things in certain instances to keep our beloved Hudson's going - greatful for members like Terry who are willing to help!
Whether it's a horn button insert or a complete engine overhaul; always seems to be a Hudsonite out there to offer assistance - Awesome!0
- 115 Hudson 1916 - 1929
