1957 Hudson Hornet Carburetor
Unknown
Any sources or recommended rebuilds for '57 Hudson Hornet 4 BBL Carter WCFB-2593-S carburetor? Car has recently been dying under load, even a slight hill in reverse or forward and even after a few minutes warmup still spits/sputters and drops out upon acceleration or ascending a hill. Little power on hill ascension as well.
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    I had the one on my 57 hollywood done by daytona carburetor they did a great job it is to nice to cover up with the air cleaner
  • Thanks Paul. I recall years ago my brother had Daytona rebuild his '56 Lincoln carburetor and they did a good job. I'll contact them for a quote.
  • PAULARGETYPE
    Trog ask for ron hewet he owns the place his son rebuilds the carbs hes and old hudson guy i've known for years tell him i sent you
  • I also do a lot of vintage carburetor restoration. Take a look at my web site for information. Lot's of happy customers.
    http://www.carburetors-rebuilt.com
    Thanks
  • MikeWA
    MikeWA Senior Contributor
    Should be a lot of specialty shops that do them- the early Corvettes also used a WCFB, I think.
    Better check the play in the timing chain. Those cars had plastic teeth on the cam gear, and if it jumps time you better remove the oil pan and you will find a lot of tooth material there. Walt.
