passenger courtesy light removal
mrsbojigger
How do I remove the two little triangular coutersy lights that are mounted up in the back seat near the passenger's head of my 4-door. I don't want to damage the bezel or glass. There are no little screws showing so I tried to carefully pry the bezel loose with a flat screwdriver but I quit since I didn't want to bend or scratch them. Whats the trick.
Chaz
Chaz
Hi,
The ones on my 49 Commodore "press" into the light recepticle - so you will have to gently pry below the edge to get it to pop off then there are 3 screws that hold recepticle in.
I used a 3" putty knife to get mine out. It distributes the force better.
Hope this helps
Dan0 -
Hi Dan,
Thanks a lot it works.
Chaz0
- 174 The Flathead Forum
- 599 Vehicles
