Front Seat Removal For '49 Club Coupe(HELP)
HornetSpecial
HornetSpecial Expert Adviser
Can't seem to be able to get front seat out of my '49 coupe. Does the front bench part come out before the rest. I looked up under seat, and could hardly get my hands in there to remove bolt's, Am I over looking something?? HELP!!:confused:
  • HUDSONNUT
    HUDSONNUT Senior Contributor
    I have a 1950 Super 6 - Just lift up on the front of the front seat and it should come up.(sort of a pressure clip that holds it in place) you then can pull the seat (bottom) up & out and then you can get to the bolts to take out the rest of the seat.
    It works that way on mine - good luck
  • HornetSpecial
    Thanks for the tip!! I tried pulling on front of bench, but did not want to break something. I will give it another try.
    Best Regsrds, Paul
  • rambos_ride
    Best Regsrds, Paul
    If I remember you want to kind of push down and back on the leading edge of the seat and then it should pop out.
    Here's a picture showing the bottom out and the tracks waiting to be removed...
  • HornetSpecial
    Thanks Dan!! A picture is worth a thousand words!!
    Paul
  • rambos_ride
    Paul
    Dont let the picture mislead you too much as it's really at about stage 2.5 from the steps outlined below plagerized directly from the Hudson Bible (thanks to Hudsonnut who pointed out most of the procedure earlier...)
    Front Seat Cushion And Seat Back
    Removal
    1. Remove front seat cushion by raising the front of cushion slightly and pulling cushion up and out.
    2. Remove the four bolts attaching the bottom of front seat frame to seat track.
    3. Remove two screws attaching seat adjusting lever to seat frame and remove seat back from car.
    Installation
    To install, reverse procedure of removal. (really, this is in the instructions!)
  • "Hudson Bible "? :confused: I obviously need one. What is it and where do I get it?
    Removal
    Installation
    Michael, I believe the reference is to the HUDSON body manual which contains assembly and disassembly insturctions.
  • hudsontech
    hudsontech Senior Contributor
    CALLING ALL HUDSON LOVERS; CALLING ALL HUDSON LOVERS.
    If anybody has one of these step-down body manuals that is not in good condition I would like to borrow it and scan it for the On-line library. I state condition because that is one of the thick ones that I would have to take apart and I don't really like taking apart manuals in good condition.
    Thank you.
    Alex Burr
    Memphis, TN
    NEChudsontech09@yahoo.com (Drop the NEC)
  • Hi!!!!!
    excuse me.... where could find a book manual body?
    Assembly and disassembly insturctions...?¿?¿
    Excuse mee to put the question in hier.
    Me also I have a tasck to learn!!!
    Bye!
  • drivergo2
    drivergo2 Expert Adviser
    Will thissystem for taking out the seat .also work on a 52 hornet.And is a mask good to use when taking out the rest of the interior its sat since 1966:confused: Thanks John
